7 Popular Wrangler Modifications
Here are 7 popular modifications that are sure to complement your Jeep Wrangler.
1. Grille Guard
Whether you are looking for a vicious look, or you want to protect the front of your Wrangler, the grille guard will give you the best of all worlds. These guards mount to the front of your frame, and they will give you the freedom of doing the most aggressive off-roading terrains without worrying about destroying your front end.
Check out this product HERE.
2. Rock Sliders
If you plan on taking your Jeep Wrangler off-roading, then there is no question on whether or not you need rock sliders. These are specifically designed for rock crawling, and they work almost like skates for when your Jeep gets stuck, as they assist in sliding your Wrangler over the rocks. Not only are these necessary to help you not get stuck, but they are critically important to protect the bottom of your Jeep from getting scratched and damaged.
Check out the product HERE.
3. Tires
Although the Jeep Wrangler was designed as an off-roading vehicle, it comes with rather normal tires for regular roads. If you want to make the best out of your Jeep, purchase off-roading tires, mud tires, or even snow tires; these will give you the ultimate traction and allow you to enjoy your Wrangler the way it was intended to be enjoyed, off the road.
4. Winch
One of the most popular modifications for the Jeep Wrangler is the Winch. Installing a winch allows you to retrieve your Wrangler when it's stuck, or help others that are stuck. These winches install to the front of your Jeep, and some of them can pull with a remote control. So you can either wrap it around a tree, or hook it to another vehicle, and get your Wrangler out of trouble, because if you're truly enjoying your Wrangler, you are bound to get stuck.
5. LED Bars
The Jeep Wrangler was designed with adventure in mind, which means off the road, off the grid, and at all times of the day. When the night comes sneaking in, you will wish you have the powerful LED bars to light up your path. These install on top of the windshield, and they are extremely powerful that nothing will be able to slow your Wrangler down.
6. Cold Air Intake
If you think your Jeep Wrangler is cool now, wait until you install a cold air intake kit. This kit replaces your air intake system, which allows it to pull cold air and push it directly into your warm engine, thus increasing its power. These kits are extremely powerful; they will give your Jeep an extra boost with a few extra horsepower, make it roar like a monster, and even decreases your fuel consumption.
Check the product HERE.
7. Lift Kit
It's time to take your Jeep Wrangler up a notch--literally. A lift kit will make your off-roading life much easier, as it will allow you to tackle much tougher terrains. The high ground clearance will allow you to go through aggressive mud, large rocks, and whatever the road throws at you, all while protecting the bottom of your Jeep Wrangler. Although this will make your ride slightly rougher on the regular roads, if you purchase a professional kit, it is still well worth it and shouldn't make too much of a difference.
For information on maintenance and repairs for your Jeep Wrangler, visit our How-To section here in JK-Forum.com!
