Jeep Wrangler JK: How to Install Tow Hitch
A tow hitch allows your Jeep Wrangler to tow various things. Learn how to install one below.
This article applies to the Jeep Wrangler JK (2007-Present).
The Jeep Wrangler is a powerful car, and even though it has the capability to tow, some come out of the factory without a tow hitch. When buying a tow hitch, be sure to research the tow hitch's capabilities and maximum towing capacity, then compare it to what you plan on towing. Installing a tow hitch is not a hard job, and since your Jeep is designed for such tasks, the frame is drilled and ready for you to install the hitch. If you can ask a friend for help, that would make your life easier, as you will need to remove the rear bumper and a helping hand can prevent bumper damage. Read on to learn how you can install a tow hitch in your Jeep Wrangler and start towing whatever it is you need to tow.
![](https://cimg1.ibsrv.net/cimg/www.jk-forum.com/425x319_85/841/41zH-91Tt3L-_SX425_-115841.jpg)
![](https://cimg1.ibsrv.net/cimg/www.jk-forum.com/1066x202_85/537/Nov-17-Tow-Hitch-117537.png)
Materials Needed
- Socket set
- Wrench
- Torque ratchet
Step 1 – Remove rear bumper
The rear bumper is held in place by a sequence of bolts. You'll find two on each side and four in the middle. Remove them all and pull the bumper off.
![](https://cimg1.ibsrv.net/cimg/www.jk-forum.com/830x415_85/845/Screen-Shot-2015-11-11-at-1-33-04-PM-115845.png)
(Related Article: How to Install Olympic Smuggler Rear Bumper - JK-Forum.com)
Step 2 – Install tow hitch
The tow hitch will bolt onto the frame, so align it and install all four bolts straight in; don't forget the nuts and washers. Lock the nut in the rear with a wrench, and use a torque wrench to torque each bolt to 80 ft/lbs.
Figure 3. Insert bolts through. Figure 4. Hand-tighten nuts. Figure 5. Tighten to 80 ft/lbs.
Step 3 – Install bumper
With the tow hitch in place, install the bumper the same way you removed it. Align it in place, then hand-tighten the side bolts. After hand-tightening all bolts, tighten them all to make sure it's nice and sturdy.
![](https://cimg3.ibsrv.net/cimg/www.jk-forum.com/830x415_85/859/Screen-Shot-2015-11-11-at-1-50-12-PM-115859.png)
Featured Video: Jeep Wrangler Tow Hitch
Related Discussions
- DIY Tow Hitch Receiver - JK-Forum.com
- Tow Hitch Install - JK-Forum.com
- Trailer Hitch Installation - JK-Forum.com
