This article applies to the Jeep Wrangler JK (2007-present).
Today's vehicles are safer to drive than ever, which is a very good thing. Unfortunately, that also means that we aren't able to enjoy or use certain features of those vehicles, all in the name of safety. One of which is the ability to play video from the screen in the dash of your Jeep while driving down the road. Obviously, distracted driving is a bad thing and no one wants people watching movies while tooling down the highway at 80 miles per hour, but it would be nice if your passenger could. Luckily, there is a way to make your video work while you are in motion, and it isn't too hard to do; just be sure and check if it's illegal in your area.
While some owners have had success disabling the factory video settings by cutting wires or installing older versions of software, these are methods that can also cause a great deal of trouble down the road. The quickest, easiest and safest way to enable video in motion is by installing a Lockpick. The Lockpick is a device that bolts into the back of your factory radio and not only allows you to watch video while the vehicle is in motion, but also enables a number of other features like wireless video and audio streaming, extra audio/video inputs, and more. Keep reading and we'll walk you through the process of installing one.
Materials Needed
MyGig Lockpick
Flat head screwdriver
Drill or driver with assorted bits
Step 1 – Remove the factory radio
Use a flat head screwdriver to pry the panel below the HVAC off.
Remove the two bolts behind the panel using either a driver or a drill.
Pry off the panel on top of the dash directly above the radio.
Remove the two bolts located on either side of the radio.
Pull out on the center dash trim starting at the bottom to remove it.
Remove the four screws holding the radio in place and pull the radio out.
Figure 1. Pry off the bottom trim piece.
Figure 2. Remove the two screws behind the panel.
Figure 3. Pry off the top trim panel.
Figure 4. Remove the two screws.
Figure 5. Pull the center console trim piece out.
Figure 6. Remove the four screws holding the radio in place and pull the radio out.
Step 2 – Install the Lockpick
Disconnect the gray connector on the back of the factory radio, as well as the white multimedia connector if your vehicle is equipped with one.
Install the gray connector from the Lockpick, then install the white connector into the open multimedia slot.
Figure 7. Connect the Lockpick harness adapter into the stock harness.
Slide the radio back into the dash and reinstall the four screws.
Set the center dash trim back in place and work your way around it, pushing it in to secure the clips.
Reinstall the two top screws, then the top trim piece.
Reinstall the bottom screws in the center trim and push the bottom piece back in place.
Test the new in-motion abilities and plug in a coordinate/destination to make sure the lock-out is disengaged.
How to Change RER to RHR for MyGIG Head Unit
Looking to update the MyGIG unit in your Wrangler? Read on to learn how you can do it at home yourself.
This article applies to the Jeep Wrangler JK (2007-Present).
The ...
How to Install LED Dash Lights That Dim
Brighten up your dash board.
More light is always a useful feature for any vehicle to have. There are several ...
How to Install XM Satellite Radio
If your Jeep Wrangler didn’t come with satellite radio, but it’s something you’re interested in adding to your vehicle, read on to learn how you can do it yourself.
This ...
How to Reset MyGIG
Easy repair of the MyGIG radio system is a click away.
MyGIG radio is a touchscreen system that can oftentimes be reset right from ...
How to Install Hardtop Wiring Harness
JKowners, Off-Road, GRD Products Co
Want to install the harness for a Jeep JK hardtop? Click here to learn how.
So ...
How to Install Car Stereo and Speaker System
dlud51, imedic31, ngiovas, 4x4LOYR
Give your Jeep premium sound quality with these modifications to your stereo.
This article applies to the Jeep Wrangler JK ...
