Whats In Our Shop In-house builds and projects
MBRP Diesel Jeep – 4 Door JK Truck
Old 03-04-2011 | 09:57 AM
  #381
saceone's Avatar
oh gawd
Old 03-04-2011 | 12:05 PM
  #382
sm_rubi's Avatar
Man this build is really becoming kick ass!
Old 03-09-2011 | 07:57 PM
  #383
fandango777's Avatar
anyway you could just take a poser shot and lean the tires up under the beast of a JK? Im just itching to see what this thing will turn out to look like
Old 03-09-2011 | 08:06 PM
  #384
bingote's Avatar
x2
Old 03-10-2011 | 01:04 AM
  #385
JKAddiction's Avatar
Originally Posted by MBRP Tech 1
The turbo's came in this week, as well as the power tank. BD Diesel has stepped up with a set of compound turbo's that are really going to give us the added boost in performance we're expecting out of this 12 valve. The 3 piece manifold will also help minimize any heat deflection or issues that surround the factory manifolds on the cummins engines...
The power tank will be mounted to the rear section of the new cage once it's complete. Here's a few pictures:
How do you plan on hooking up both turbos?? I only see one mounting spot on the manifold for a turbo... This is an AWESOME build guys, and I cant wait to see the finished product...
Old 03-10-2011 | 07:10 AM
  #386
MBRP Tech 1's Avatar
Sponsoring Manufacturer
MBRP Representative
I'll address this with today's updates...lots of great pictures coming...
Old 03-10-2011 | 08:25 AM
  #387
MBRP Representative
More updates today! The roll cage is being built for a few reasons...Both safety and to build rigidity in the frame. The roll cage is both frame, and body mounted using bushings and mounting plates. This allows us to completely remove the body, with the cage still in tack, yet it ties everything together when the body is mated to the frame. The cage is all hidden inside the custom hard top, and the freedom panels will still be completely functional and removable.
Here are a few shots of the early stages:
Old 03-10-2011 | 10:14 AM
  #388
Uafan's Avatar
This is the coolest project I've ever seen.
Old 03-10-2011 | 12:10 PM
  #389
MBRP Representative
These pics show the extension tubes that extend forward through the cowl into the engine bay. They have slugs welded in them for attaching the engine bay structure to them and they are welded to the front side of the A-pillar vertical bars.
The crossbar for behind the dash is done and the 3rd upper cross bar is in place. Tomorrow the dash will be modified to fit back in.
Old 03-10-2011 | 12:12 PM
  #390
MBRP Representative
Twins are in place. Not set completely, but in place. A little different mounting location especially for the lower (primary) turbo would be nice for fitment of the turbo itself as well as the down pipe, but it can be made to work. We're still playing with some ideas to maximize room in the passenger foot well area at this point...
Quick Reply: MBRP Diesel Jeep – 4 Door JK Truck
