MBRP Diesel Jeep 4 Door JK Truck
#252
Sponsoring Manufacturer
MBRP Representative
MBRP Representative
We have had a few new additions to our sponsor list, and would like to say thanks again to everyone who has helped us out with this build. Here is the list as it stands right now...
Mastercraft Safety - Baja RS suspension seats, 5 point safety harnesses, grab handles and suspension limit straps
Rock Krawler - 2 5/8" Prodigy Emulsion Coil over shocks at the 4 corners
Currie Enterprises - Hi Pinion Dana 60 in the front, and Dana 70 HD in the rear
Axletech International - Portals
Rigid Industries - LED light bars
Stazworks - custom made bead lock wheels
FASS - complete Titanium fuel system
BD Diesel - twin turbos, pumps, etc
South Bend Clutches - Clutch and heavy duty pressure plate
Autometer - Gauges
Pitbull Tires - 44" Rocker's
Eaton - lockers
JE Reel - Driveshafts
Xtreme Customs - Paint/body
Kat Kustoms - chassis
Autometer - Gauges
Eaton - lockers
#253
#255
Man and to think the Mighty "C" is 1175 pounds Head , Block , Crank , Rods, Pistons, Timing Gearcase , P7100 , and valve cover LOL. I remember the first time I pulled the head off a buddies dodge. ... yeah 227 pounds fo dead iron .. use picker LOL
Say I don't remember but are you going to run a D60 up front? The 30/44 will crumple with engine weight LOL
#256
MBRP Representative
MBRP Representative
I personally just found out about the Portals today! These should be built to support the extra 1000+ lbs up front.
#257
I dont want to call your masterpiece ugly but it needs something to finish the line back there. even a bedlined roll-over painted black might finish the line or add enough relief.
#258
MBRP Representative
MBRP Representative
I think a tube the same width as the rock sliders (if your going tubular like the rendering) would finish the line.
#259
MBRP Representative
MBRP Representative
We have some good shots of the progress made the past few days. The fire wall was cut back to make room for the motor/trans and is sitting in place. This should give you an idea of how large this motor really is compared to the stock 3.8L.
Now that we have a rough idea of where the motor needs to sit, we can begin the process of reinforcing the frame, adding motor mounts and so on... This was a big step in the right direction.
