View Poll Results: Which Mod would you Like to See Added
2.5 Inch King Bump Front and Rear
0
0%
Voters: 15. You may not vote on this poll
Jeep JK Punisher Edition Build Log Full Custom Jeep by Del Rey Customs
#521
#524
Have you flexed it out yet to check for tire rubbing and to properly adjust the bump stops? Also, those rear brake lines look a little short, at least from the pics you posted. In your third and fourth picture, it looks like the upper brake hose mount (where the new braided hose meets the OE hardline) is mounted upwards, thus taking up allot of hosing. Are you sure those brackets weren't meant to be facing down, which would have given you much more usable brake hose length?
Also, as others have suggested, get rid of any component that uses cam adjusters, especially the front and rear track bar mounting locations.
#527
#530
Jeep JK Wrangler Custom Ipad slider indash Dash Kit For 2007 up
http://youtu.be/T0E3JybyWfY
So as we continue on our Journey we would like to welcome you to episode 30 where we are officially starting the Audio and Lighting upgrades on the Jeep Punisher Edition. The first step on any custom audio system is the source unit which is this modified jeep JK dash Kit built by Delreycustoms.com the kit allows you to mount ans iPad Mini (retina) in the dash instead of the stock radio. we have many options on this molded kit to transfer audio to a high end audio system.
From Using an aftermarket radio down in the Tuffy Box via USB to High End DTA converters to straight BT streaming Via Mosconi AMP or DSP with built in Bluetooth,
We also offer the Dash Kit pre-made and can ship them to you ready for install. If you have always wanted to iPad your Jeep JK we have the kit for you.
Feel Free to contact Saturn @ Saturndrcmedia@gmail.com
We have several stock dashes in stock and modified for easy installation. Just clip off you stock dash, remove the radio and clip our dash into place. Quick and simple with a factory style bezel. Nice this is security you can take you iPad mini with you so there no radio to steal if you choose to leave your door off the vehicle, have a soft top or even no top at all. Fits all 2007 and JK and JKX body style including the Rubicon, Sahara and Sport.
