2016 Jeep JK Wrangler Phase One Build 75th Anniversary "Bronze Tanner"
2016 JEEP JK WRANGLER PHASE ONE BUILD 75TH ANNIVERSARY BRONZE TANNER
Axles:
DANA 60 FRONT ROCK JOCK VXR AXLE - CURRIE ENTERPRISES
- ARB AIR LOCKER
- CUSTOM WIDTH FOR 37 INCH TIRES
- F450 KNUCKLES
- HEAVY DUTY TIE ROD
- 5:38 GEARS
- MASTER INSTALL KIT W/ BEARINGS
- ALL BRACKETS INCLUDED
- 1350 YOKES
- 6 ON 5.5 BOLT PATTERN
- DIFFERENTIAL COVER
DANA 70 REAR ROCK JOCK AXLE
- ARB AIR LOCKER
- FULL FLOAT
- 5:38 GEARS
- ARB LOCKER
-40 SPLINE
-1350 YOKE
-6 ON 5.5 BOLT PATTERN
-DIFFERENTIAL COVER
Air Compressor:
ARB AIR LOCKER MANIFOLD KIT
ARB INFLATION ACCESSORY KIT
ARB TWIN AIR COMPRESSOR
MORE OFFROAD ARB TWIN AIR COMPRESSOR MOUNT
AEV PRO CAL
Driveshafts:
FRONT JE REEL 1350 CUSTOM DRIVESHAFT
REAR JE REEL 1350 CUSTOM DRIVESHAFT
Suspension:
CURRIE ENTERPRISES ANTIROCK ALUMINUM FRONT SWAY BAR KIT
CURRIE ENTERPRISES ANTIROCK ALUMINUM REAR SWAY BAR KIT
RECON FRONT BOLT-ON HYDRAULIC BUMP STOP MOUNTS (PAIR)
RECON FRONT COILOVER MOUNTS FOR 12" 2.0 / 2.5 COILOVERS
RECON KING AIR BUMPSTOP 2.0 4" (LIMITED TO 2") - BLACK FINISH
RECON KING COILOVER 2.5 12" REBEL SPEC
RECON KING COILOVER 2.5 14" REBEL SPEC (REAR ONLY)
RECON KING COILOVER COMPRESSION ADJUSTER 2.5 (EACH)
RECON KING COILOVER INTERNAL BYPASS (2.5 ONLY) (EACH)
RECON REAR BOLT-ON 14" COILOVER MOUNTS
RECON REAR WELD IN BUMPSTOP MOUNTS
REBEL OFF ROAD EXCLUSIVE TERAFLEX LONG ARM UPGRADE FOR RECON COILOVER CONVERSION
Brakes:
REBEL OFFROAD-RESTRAINT COMPLETE BRAKE KIT (DANA 60 AND 70)
KIT INCLUDES:
- 2x RESTRAINT FRONT ROTORS (DOUBLE DRILLED & SLOTTED)
- 2x RESTRAINT REAR ROTORS (DOUBLE DRILLED & SLOTTED)
- 1 SET OF FRONT PADS
- 1 SET OF REAR PADS
Bumpers:
POISON SPYDER ROCKBRAWLER II REAR BUMPER WITH TIRE CARRIER
RIGID D SERIES PRO FLOOD DIFFUSED
Wheels and Tires:
METHOD RACE WHEELS
- 101 BEADLOCK
TOYO OPEN COUNTRY M/T 37X13.50R17
Exhaust:
BORLA CLIMBER CAT BACK EXHAUST SYSTEM
Hood:
DV8 HOOD – Paint Matched
Shifter:
B&M Short Throw Shifter
Seat Recline Kit
J.W. SPEAKER LED JEEP TURN SIGNALS MODEL 239 J2 SERIES
Custom Race Roll Cage
Axles:
- ARB AIR LOCKER
- F450 KNUCKLES
- 5:38 GEARS
- 1350 YOKES
- ARB AIR LOCKER
- FULL FLOAT
- 5:38 GEARS
- ARB LOCKER
-40 SPLINE
-1350 YOKE
-DIFFERENTIAL COVER
Air Compressor:
AEV PRO CAL
Driveshafts:
Suspension:
Brakes:
KIT INCLUDES:
Bumpers:
Wheels and Tires:
METHOD RACE WHEELS
- 101 BEADLOCK
Exhaust:
Hood:
Shifter:
Seat Recline Kit
2016 Jeep JK Wrangler Build 75th Anniversary "Bronze Tanner" - PHASE TWO
Bronze Tanner came back for some more upgrades and goodies!
Artec Inudstries Nighthawk JKU Sliders - CT Bronze Powdercoated
Poison Spyder Bruiser Bumper - CT Bronze Powdercoated
KC Hilites G34 LED Pair
Warn Industries Zeon Platinum 12000lb Winch
Warn Spydura Synthetic Line
Poison Spyder Aluminum Hawse Winch Fairlead - Mojave Sand Painted
RockHard 4x4 Bolt-in Sport Cage w/ rear center cross bar - Mojave Sand Painted
Alcon D60 Big Brake Kit
PSC Steering JK Ram Assist Steering Kit
3/4 D Rings w/ Daystar D Ring Isolators
Factor 55 Red Pro Link Loaded
