Will an 07-09 soft top fit on a 2010?
#21
i think the 07-08 only work on these years the 09-10 i believe are the same if in doubt look at quadratec.com they sale tops and sometimes you can tell by what they are listed as. the 09-10 front latches are different than 07-08 i think they are in a different place.
#22
I have a 2008 soft top on my 2009 unlimited. I did have to modify the header a bit due to the footman loop relocation in 2009 though.
Not a great picture, but here is what I had to modify for the top to lay down properly:
#24
Where it snugs up against it though, it can prevent it from seating all the way in the middle. You're right though, it's not a big deal. A utility knife and 1 minute of scraping a little plastic off and it would fit good.
I think the new header (the metal TSB replacement one) only has 1 part number, so I'm assuming the footman loop cutout is enlarged in a way that it fits perfectly on any year. Therefore, if you didn't want to trim the plastic, you could install the new header.
#25
Have an 07 in an 10
I bought an 2007 top on craiglist for $400 and just installed on my 2010. Fits perfectly. I did try to flip the front section of top to expose front cab but had a problem. Not sure if design is differnet or if am just doing it incorrectly.
