Why would you turn traction control off?
I believe you are taking about the ESP Button? I wondered that myself, here is a relevant article that will tell you everything you want to know. '07-Present Wrangler's Control System - ESP Off - Jp Magazine
When you need wheel spin. Like drifting in snow covered parking lots and hauling @$$ on gravel roads.... That was a joke. More or less its when you need more wheel spin or momentum
Hence why many put in a ESP kill switch.
My steering wheel was off center so made my traction control go wild. So i disabled it. Fixed my streering wheel just need to get it back on. Plus i like sound of burnouts once in a while. Ha
ESP (actually Jeep calls it ESC, same thing) will stop you dead before it lets your wheels spin. So, you can become stuck when ESC is off, or stuck because it is on. I don't like it much, but then I've stayed out of trouble without it for 50 years.
Lets say you just washed off your vehicle, its dripping wet, you go to merge onto a roadway and floor it a bit as a vehicle is comming over a slope. With ESP your tire slip will slow the RPM's, the vehicle will seem like its shutting down, it will save you from a slide, but slow you to where when you step on the gas you get nothing for a second or more. You might get hit by that vehicle comming over the slope as the vehicle shuts down for safety. Without ESP your tire slip will go, you may clean the tires quick and shoot straight down the road you want, you may slide and need to control with your throttle and could spin out and crash.
If your not a great driver ESP will help you when panic sets in. If your a great driver you might do better with no ESP as it could slow you down/get you stuck.
If a sports car had ESP active all the time, it might as well be a daily driver sedan as it would not be able to push the limits on a track/road course or launch well off the line.
