whistle sound at low speed
driving with window down heard a whistle sound or sweeping sound like if sheet metal was riding on rotor ..I .chkd for all of that...does it with engine off coasting in neutral and all other times ..almost like belt sueak spray has that sticky rubber to metal sound....pretty strange....factory deer guard?? I can't tel whether its front or back....anybody else have it??? doesn't change pitch or volme and only goes away right before vehicle stops???
Me Too
I have the same problem have already taken it in they lubed up the dry seals in front this did not wirk i have it there today again i think it has something to do with the rotors or calipers as there definitely sounds as if something is scratching the shit out of the discs.....also have a whistling noise coming our from under the hood at 2000 rpm's there's a tsb for this but not for the JK go figure I have it there today for this as well and i put the tsb in there with it to see if they'll do it....I'll let you know the outcome
kewl...Yea I'm beginning to think it sounds more like rubber tire on polished concrete floor sound but constant...maybe the rubber boots on driveshaft
I have the whistling tune as well. It is definitely coming from the engine compartment. It happens when I get on the gas, no matter what speeds. As soon as I let off the gas, it stops. Seems to be getting worse or mabe I am just noticing it more. Unfreakinbelievable, another problem to add to the list.
