Where is my oil going?
Hi Widewing. I haven't checked the oil between oil changes. And off course the time the dealer did the oil level remained normal. I didn't add any oil to it either since I hadn't checked it. Besides I'm not dealing w/a 200 thousand miles engine here so it shouldn't go/burn oil like that.
People who own/drive vehicles need to check things once in a while. That's good maintenance practice.
There are only three ways an engine can lose oil. Leaking, burning and passing through the crankcase as a mist and ultimately into the combustion chamber from below. That last one would be what I would look at first. It would be cause by a restricted PCV system. If you're not seeing any smoke out of the tailpipe, or any leaking, the PCV system is where I'd put my money.
It's not leaking... What you are seeing is normal oil consumption.
What you need to do, at the minimum, is to check your oil level at increments not greater than 500 miles. Every fill up would be even better. Buy a couple of extra quarts of oil when you change oil. Keep one quart in the storage cubby under rear floor. When you find the oil level is down to the fill mark on the dipstick, add the quart. Put another quart into the cubby for the next time.
Keep the crankcase filled, and the next time you change the oil, you'll drain the proper amount of oil.
I can't overemphasize how vital is is to maintain the correct volume of oil in the engine. Should you suffer engine damage due to a lack of oil, it will not be covered under warranty. Damage could be something like scuffed pistons, worn valve train or damaged main bearings. Perhaps one day you may notice a knock on start-up that goes away as oil pressure increases. That is a strong indication of worn bearings. One day, the knock won't stop. Eventually, you'll spin a bearing.
Please, follow the procedures in the owner's manual.
My regards,
Widewing
My regards,
Widewing
If you don't do this, sooner or later the engine will be damaged. When the dealer tears it down, damage from oil starvation is easy to identify. What that means is that the repairs will not be covered. You will pay for the repair yourself, and that can run into several thousand dollars.
So, please read and follow the basic maintenance requirements in the owner's manual. You're damn lucky not to have killed the engine already.
My regards,
Widewing
I used to run Royal Purple until I felt it was using more oil than it should be. Then I read here on the forum that a few others noticed the same thing. They changed brands and so did I. I'm running Mobil 1 and so far so good. Next time you change your oil you might consider changing to a different brand and see what results you get.
Read my last post... You must check the oil frequently and replace that which is consumed.
My regards,
Widewing
My regards,
Widewing
Did you check your oil before you drained it?? Was it reading anything on the dipstick?? Is it possible the drain plug in the pan is clogged and you never got All of the oil out?
Someone had already mentioned the oil filter and you said you checked that, but i have seen twice now where the old gasket from the filter stayed behind and the shop did not catch it and put a new filter on. The double gasket resulted in a severe leak, which may not leave as big of a trail as expected, but a puddle somewhere... I am sure this is not your problem, but for others doing and having your own oil changes be aware.
