where can i get through the fire wall
Old 02-23-2009, 06:43 PM
White Widow's Avatar
Default where can i get through the fire wall
im trying to add a cb in the jk but where do the wires go through the fire wall i looked for about an hour (in the dark) couldnt find any where to go through the fire wall
Old 02-23-2009, 06:48 PM
mkjeep's Avatar
I drilled a hole , on the passenger side underneath the battery. Then found out theres one you can get to on the pasgr side behind the dash side plate has to come off. On driver side, hole in firewall on autos where the clutch would go.
Old 02-23-2009, 06:49 PM
mkjeep's Avatar
Look at WOL's cb write up http://project-jk.com/jeep-jk-write-...nd-model-1001z steps 19-22
Old 02-23-2009, 06:54 PM
mkjeep's Avatar
I wish I'd saw the write up before I drilled Anyway, I've got an easier acess hole now
Old 02-23-2009, 07:00 PM
i thought about going that rout but when i take the windshield down it wont work, it seems as it the drilling a hole would be easier then going through that rubber wrapped boot on the pasenger side.
Old 02-23-2009, 07:03 PM
JK-KJ's Avatar
Yep, this is the easiest option in my opinion.....this is what I used on mine.
Old 02-23-2009, 07:05 PM
mkjeep's Avatar
I drilled a hole and put a piece of 3/8" fuel line through it and ran the wires through that. Zip tied on each side so it doesn't move. Probably silicone it wouldn't be bad either.
Old 02-24-2009, 05:33 AM
undertow119's Avatar
If you have an automatic, there's a hole on the driver's side near your feet where the clutch pedal would be. It's covered with a rubber plug, but you can pierce right through that to run wires. That's where I ran all of mine.
If you have a stick, you're on your own .
Old 02-24-2009, 06:01 AM
saltman's Avatar
Why would it not work putting down your windshield? I did it that exact way(through the whole on passenger side near battery) on my 2007 and put the windshield down many times. I am speaking purely of the hole. I used the cooltech mount and routed the wires around the trim and under the dash. IMO that hole in steps 19-22 is the way to go.
I guess you are saying the cb location in that write up wouldn't work. I agree.
Old 02-24-2009, 07:40 AM
JIMBOX's Avatar
I'm sorry, but this pic is sideways
If you look close, I ran a 7-pin trailer cable, thru that hole on the passenger side
It handles all my wiring for driving lights/back-up lights and CB
You can route the wires RIGHT TO THE BATTERTY THRU THAT HOLE-STRAIGHT (almost)
Can't beatit
JIMBO
Quick Reply: where can i get through the fire wall
