Whats this fluid?
#41
![what?](https://www.jk-forum.com/forums/images/smilies/aaah-what.gif)
#42
ok...my trans lines are leaking too. I just tied in a B&M trans cooler and used the brass barbed fittings. Can i just cut the metal crimped lines out and use the rubber hose that i used for the trans cooler?
#43
Ok I have the same leak(the 2 lines just under the coolant tank if you were looking straight up from underneath) and my power steering fluids a bit low. My question is this, some posts say its a tranny line and some say its from the power steering so which one is it?
#44
yea that is what mine did but not that bad dealer replaced watched them do it took like 10 min jacked in the air looked fairly easy.
#45
or check out the posts earlier in this thread for some photos of trans lines and power steering lines:
#46
Well I'll be damned took another look and the hose says transmission on it plain as day! I'm thinking it just started because I checked the level twice and its fine. And no drip spot any where I usually park. Maybe all this cold we've been having.. Shrinkage you know!
#47
I can only guess why the engineers put in a short section of hose in the line. (dampen vibrations??) But those crimps have leaked on quite a few rigs.
good luck with the shrinkage.... and the transmission, too!
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
you do have an auxiliary cooler, right?
