What is your Gross vehicle weight?
Your help is needed!
I am trying to crate a special towing chart for the Jeep Towing Guide thread.
BUT!
I can't find a reliable source for the "Gross vehicle weight rating" for each trim level.
If you can help, please check the decal on your door jam, driver side for GVWR,
and specify your trim level: 2dr, 4dr, axle ratio, X, Shara, Rubicon
Thanks!
*Last update Jul 18
2dr X Sport 3.21 = ???
2dr X Sport 3.73 = 4900lb
2dr Sahara 3.21 = ???
2dr Sahara 3.73 = 4900lb
2dr Rubicon 4.10 = ???
Unlimited X Sport 3.21 = ???
Unlimited X Sport 3.73 =5400lb
Unlimited Sahara 3.21 = ???
Unlimited Sahara 3.73 = ???
Unlimited Rubicon 4.10 = 5700lb Confirmed!
BUT!
Thanks!
*Last update Jul 18
I went to purchase some rock for a project and the place has you drive on a scale before and after to get how much you owe (2 cents a pound for road mix). My X unlimited 07, soft top and rubicon tires full tank of gas and me (228 lbs) was 4700 lbs so subtract the 228 and the rubicons are way heavier than my stock 17 in Wranglers SRA's.
Maximum Payload
(includes occupants & cargo) 1,000 lbs. (373 kg)
2009 Wrangler Unlimited 1150
Curb Weight
Wrangler X, Man. Trans 4075 lbs. (1848 kg) +1000 = 5075=
Wrangler X Auto. Trans 4100 lbs. (1860 kg) +1000 = 45100=
Wrangler Sahara, Man. Trans 4269 lbs. (1936 kg) +1000 = 5269 lbs
Wrangler Sahara, Auto. Trans 4294 lbs. (1948 kg) +1000 = 5294 lbs
Wrangler Rubicon, Man. Trans 4315 lbs. (1957 kg) +1000 = 5315 lbs
Wrangler Rubicon, Auto. Trans 4340 lbs. (1969 kg) +1000 = 5340 lbs
Curb Weight
