What oil do you recommend for the differential?
BTW, I just use GL-5 rated 80w-90 dino lube, as per OEM specification. I really don't believe I'll leave it in long enough to reap any benefit from anything more fancy.
Most standard oils require the additive for the LSD. One of the nice things of the Royal Purple (I -think- but am not sure that Mobil 1 is the same) is that LSD additives are already in there. So it is just a matter of draining out the old oil and pouring in the new stuff
im a fan of the royal purple as well... i got a decent deal on mine at a local auto parts store but had to pick up an extra qt at a different store and had them price match
You can't go wrong with any lubrication fluid that meets the spec.
With that said I'm a believer in synthetics so at 15K miles, I chose Amsoil 75/140 for the rear. Only because I tow our jetboat every summer. For the front it was Amsoil 70/90.
By the way I do believe you can get Mobil 1 with the additive already in the formula. As a matter of fact seems I saw quite a few synthetics with the LSD additive already incorperated. A bit more expensive than the regular though.
just finished changing mine tonight - went with Mobil 1 in both the front and the rear. Did an oil change as well - the differentials were almost as easy thanks to all the advice on this forum!
