what kinda warranty does an 08 JK have?
if you picked it up late 2008, sept ,of, nov, or december you are still covered under the 3 yrs, 36,000 miles bumper to bumper.granted the miles are under 36,000 miles.
I am already over on miles, i was just thinking maybe the emissions had a longer warranty. I have had a few other cars that had exhaust leak around the header and had the dealer repair it under emissions warranty which was like up to 100k miles.
i found this , i think maybe its covered.
5.1 Federal Emission Warranty
A. Parts Covered for 2 Years or 24,000 Miles
Federal law requires Chrysler Motors LLC
("Chrysler") to warrant the following emissions
parts for 2 years or 24,000 miles, whichever occurs
first. Chrysler covers all of these parts under the
Basic Limited Warranty for 3 years or 36,000 miles,
whichever occurs first.
• Air system controls;
• distributor and its components;
• electronic fuel injection system, including
injector;
• evaporative-emission canister and controls;
• exhaust manifold;
• exhaust gas recirculation valve and control
system;
• exhaust pipes (between exhaust manifold and
catalyst);
• fuel cap and tank assembly, pump, and fuel
lines;
• ignition coil and ignition module;
• intake manifold;
• on-board diagnostic-system components;
• oxygen sensors;
• positive crankcase-ventilation (PCV) valve or
orifice;
• secondary ignition wires;
• spark plugs;
• throttle body;
• transmission-control module;
• vacuum hoses, clamps, and fittings, as well as
tubing used for these components;
• vacuum, temperature, altitude, speed, timesensitive
valves, sensors, and switches used in
these components and systems.
B. Parts Covered for 8 years or 80,000 miles
If your vehicle has one of the following parts, this
Federal Emission Warranty covers that part for a
period of 8 years or 80,000 miles, whichever occurs first.
These limits are counted from the time when your
Basic Limited Warranty begins under 2.1(E). The
covered parts are:
• catalytic converter; and
• powertrain control module.
injector;
• exhaust manifold;
system;
catalyst);
lines;
• intake manifold;
• oxygen sensors;
orifice;
• spark plugs;
• throttle body;
covered parts are:
