What goes here?
What goes here?
Almost done with my rebuild but i have totally forgot something.
The motormount goes into the top right hole in the picture, dipstick to the left but what goes in the hole below the plug??
I also need that plug but i cant find it anywhere.
Help, please...
No picture attached.
The big hole is flat, no thread. Starting to think that maybe its used in another application.When i took the engine out the surface was all rusty.
And the engine mount cover it up pretty good so i cant see how anything can fit there. However the channel behind the hole seem to go aginst the timing cover.
Yes i have managed to find some other examples where this hole was left open to. Or did you mean not to worry about not remebering stuff?
Btw, do you know the size of the plug above the hole? Been looking at 1/4 and 3/8 hex but when i measure it seems to be somewhere in between. No sense in that.
The top hole is feed from the oil pump and does require a 3/8" npt. lower hole is left open, unused with the jeep front cover.
JW1977 (03-07-2022)
