What gears do i have?
Old 06-22-2009, 08:25 AM
toyfreak's Avatar
Default What gears do i have?
i have 4:10's
went to the stealership and had them pull the vin
thanks guys
i bought a used 07 unlimited, standard tranny, 4x4, and i would really like to know what gears i have in it. Is there any way to find this out? The sticker on the axel is worn.
thanks
Old 06-22-2009, 08:29 AM
ckmehl's Avatar
Default uhmmmmmm
if it has the trail rated badge on the side you have the 3.73's. thats pretty much standard. the only other thing i can tell you is to call the dealer and give them your vin number. they can tell you that way.
Old 06-22-2009, 08:30 AM
Matador's Avatar
Plug your VIN in here to the Jeep site and it should tell you
http://www.jeep.com/en/owners/
Old 06-22-2009, 09:41 AM
toyfreak's Avatar
thanks guys
Old 06-22-2009, 03:11 PM
ronjenx's Avatar
thanks
If you want to know for sure, and remove all doubt, do this:
Chock the front tires, fore and aft.
Put the transmission in neutral.
Emergency brake off.
Jack the left rear tire off the ground.
Put a jack stand under the frame, just in case the jack fails (had to add this).
Put an index mark on the aft end of the drive shaft, visible from the left rear wheel.
Put an index mark on the left rear tire at the 6 o'clock position.
Rotate the left rear tire 2 complete revolutions while counting how many times the index mark on the drive shaft passes its original position.
That number will be your axle ratio.
Remove jackstand and lower jack.
Put transmission in gear and/or apply emergency brake.
Remove chocks.
If you have limited slip, jack up both rear wheels and rotate one revolution, making sure both tires rotate equally.
If the driveshaft rotated almost 3 1/4 turns, you have 3.21
If the driveshaft rotated almost 3 3/4 turns, you have 3.73
If the driveshaft rotated a little over 4 turns, you have 4.10
Old 06-22-2009, 05:35 PM
Clubcar's Avatar
I have a wrangler x with s package (2008). It has a trail rated badge (don't all wranglers?)
the window sticker says:
3.21 Axle Ratio
Next Generation Dana 44 Heavy Duty Rear Axle
Next Generation Dana 30 Solid Front Axle
Which now disappoints me...
Old 07-22-2009, 08:50 AM
BlackNorthernJK's Avatar
Nope.
3.73's didn't exist in the '07 model year. Either 4.10s or 3.21s
Old 07-22-2009, 08:52 AM
thanks
More info dude. Sahara, X, Rubicon ?? Tow package or not?
Ronjenx has the definitive answer for sure.
So you know. Typically the Standard X without tow package was the only one that came with 3.21's....pretty much everything else had 4.10's that year
Old 07-23-2009, 05:42 AM
JulianK's Avatar
Excuse the dumb-@ss question but what's in the tow group? I thought it was just gearing but on the site it says:
With 3.73 Axle Ratio You Can Tow 1000 lbs
With 3.73 Axle Ratio and Trailer Tow Group You Can Tow 3500 lbs
Old 07-24-2009, 03:56 PM
Chris333's Avatar
uh mine has the trail rated badge and i have 3.21's you dont know what your talkin bout
Quick Reply: What gears do i have?
