Weird cracking sounds from front left wheel when turning :S
My Jeep is only 4 months old, just installed some Daystar shock spacers recently and a little bit afterwards I started noticing a 'crackeling' sound coming from the Front-Left wheel only when I turn right.
I am not sure if something needs to be greased up or anything, doesn't do it on the other side, and it didn't do it when I first bought the jeep.
Here is a video, listen at 10 seconds: http://www.youtube.com/watch?v=5ZP12lkkyLA Thanks for the help!
I had the same sound after I installed the leveling kit (spacers). Turns out I installed one of the swaybar links backwards and one of the bolts was loose. I reinstalled the link the correct way and re torqued and the problem was gone.
FIXED! It was indeed the nuts, for some reason one was pretty loose and the others (except the lock) were not super tight.
Thanks for the help, didn't think it would be that easy.
