Wearever brake pads?
Just bought and put on Wearever Silver brake pads and they squeak like crazy. I know pads are going to do that when initially put in but it's been a month already. Anyone else use these pads?
Ceramic was the way to go. Your pads are probaby semi-metallic. Some brands will squeel based upon metal content. That's the price you pay for increased pad life. Cheaper brands will squeel also. This might help.
Types of brake pads
There are four general types of brake pads for cars and trucks:
Semimetallic: This formula, containing about 30 to 65 percent metal, typically includes chopped steel wool or wire, iron powder, copper or graphite mixed with inorganic fillers, and friction modifiers that bond all the ingredients together. These pads are more durable and have excellent heat transfer, but also wear down rotors faster, can be noisy, and may not perform optimally at low temperatures.
Nonasbestos organic: Sometimes listed as organic or NAO, this type of pad is made from fibers, such as glass, rubber, carbon, and Kevlar, with filler materials and high-temperature resins. These pads are softer and create less noise, but they wear faster and create more dust.
Low-metallic NAO: These are made from an organic formula mixed with small amounts (10 to 30 percent) of copper or steel to help with heat transfer and provide better braking. With the added metal, there is more brake dust and they may be slightly noisier.
Ceramic: These are composed of ceramic fibers, nonferrous filler materials, bonding agents, and possibly small amounts of metal. Lighter in color and more expensive than other brake pads, ceramic pads are cleaner and quieter, and offer excellent braking characteristics without wearing down the rotors.
Types of brake pads
ht tp://brakeperformance.com/index.php?ad=google&gclid=CIna24zHx7ECFUXc4AodNE8A OQ
They have great breaks and rotors
Didyou grease your slide pins and the back of the caliper where the piston seats against it. I put these pads on a F150 and Trailblazer and neither are squeaking.
