water sound while rocking jk
Old 11-07-2008 | 05:50 AM
dyolfknip's Avatar
A buddy of mine got stuck in a pretty deep "puddle" and his doors filled with water and didnt drain due to the mud....try taking your doors off and see if it is them....
Old 11-07-2008 | 06:05 AM
HappyCurmudgeon's Avatar
Eternal ***erator
drink less beer.
wait... did I just say that?
Old 11-07-2008 | 06:11 AM
07JKX's Avatar
did you ride through any deep watter or mud? if so and you are still running your stock bumpers, the drain hole can clog (primarily on the rear) and hold water in them.
i had the rugged ridge sidesteps and they filled with water and the drain hole was plugged.
Old 11-07-2008 | 06:12 AM
Eternal ***erator
LMAO!
we have ballast tanks?
That is funny!
Old 11-07-2008 | 06:20 AM
07JKX's Avatar
Originally Posted by HappyCurmudgeon
LMAO!
That is funny!
yup!
i pulled my steps to exhange for sliders for tellico... pickup the step, heard water... founf the hole in the bottom... of course hold the steps about face level and poked the mud out... you can guess what happened from there.
Old 11-07-2008 | 06:23 AM
Eternal ***erator
yup!
Nothing. Nothing happened at all. :-|
Old 11-07-2008 | 09:19 AM
Choppus's Avatar
Originally Posted by JK-Q8
It could be the ac drain or watever its called. my dad had it on his grand cherokee. its normal when you park the jeep and you had the ac on you see it dripping water, you might have that opening blocked and the water just stays in there. check it out it could be that.
There is no "drain" on the AC system!!! The only reason it drips is because of condensation to the outside of the AC system!
Old 11-07-2008 | 09:45 AM
RedRockJk4x4's Avatar
I used to have a blazer that had an air pocket trapped in the heater core up under the dash and the cooling system made some weird gurgling/water sounds. Is your cooling overflow tank full? It could also be the windshield fluid tank sloshing around. I would top everything off if it isnt already and see if the sound changes to make sure it isnt one of these things. Hope you figure it out.
Old 11-07-2008 | 10:07 AM
edwin907's Avatar
It's the mirrors, they are half full of water!
The next rain they will fill the rest of the way up and you won't hear it anymore!
Seriously, check the freedom top panels.
Old 11-07-2008 | 10:46 AM
vs_jk's Avatar
Most likely it will be the freedom top panels. I had that same issue but then found there is a small hole on front of the passenger side panel. It looks like a slight plastic molding flaw but can easily be filled in and solves the issue.
Quick Reply: water sound while rocking jk
