Water Leaks
Water Leaks
I have an 11 2 door Rubi hardtop with water leaks. Originally just in the front. I thought I cured that one. But now, I have water leaking in from the roof panels coming down over the sound bar on both sides. Anyone suffering with an 11, with these problems? I know the roof is "New" from a different distributor and this is a 2 door. I had an 09 4 door and had no leaks. Chasis flex, more on a 2 door? I'm at a loss because generally there is no fix for water leaks. Thanx, Harry
If it's still under warranty then take it to the stealership and get them to check it out.
Did you recently take the top off? Make sure you sealed it right when you put it back on or it will do what you are saying.
