Water gurgling noise from dash. Sounds like JKU is about to have explosive diarrhea!
#21
At work about to take lunch and I saw this
I thought it was power steering or trans fluid cuz the new jks have the problem with the lines rubbing together.
So I had it towed 50 miles to the dealer.they said it was coolant and they wanted to pressure test it over night.
And they gave me this crap and it wasn't even 4wd. My jk passed the test and I haven't had a problem with the explosive diarrhea lol. I'm still stumped about it tho.
#22
just lift the rental car put some bigger tires..and tint the windows, you wont notice the difference
Attachment 385180
Attachment 385181
Attachment 385182
Attachment 385183
Attachment 385180
Attachment 385181
Attachment 385182
Attachment 385183
#23
Sloshing and gurgling water noise under dash of my 2013 JKR
Took my 2013 Rubicon (with less than 200 miles on it) back to the dealers after I started hearing the sloshing noise under the dash. Every time I started the car, when I accelerated or turned a corner, I'd hear this noise, like the sound of water being flushed through pipes. They purged the cooling system, but the noise was still there. No leaks were detected. They told me to give it some time – maybe as much as a month. It kept getting louder and more frequent, so I took it back. This time they raised the front end of the jeep in order to lower the heater core location so that it would be below the radiator inlet opening. They also put a high pressure radiator cap on. That seemed to work for about 4 days, and then the noise slowly started to gurgle back. I'm taking it in one more time. Now I'm wondering if it's a faulty heater core or head gasket. The service manager admitted that they've seen this problem in other jeeps, but they've usually been fixed by bleeding the system…
#25
my 2012 has the same problem since new, I have 13 000km on it right now, and the noise is still there.
I also have the heating issue (near to no heat on driver side). Don't know if they're related though. Have an appointment in 2 days, can't wait to get my heat back! It's being cold and colder these days
#26
WTF
#28
They can't fix it today at the off road shop.
Apparently there's a bulletin out about driver side not getting equal heat. Passenger vents were at 140*+ and Driver was at 110*
There's some flushing of the heating system with some chemical that needs to be done. Ugh.
