Warning Water in Storage Space
Still not fully dry yet. I have done everything but pull the carpet. I have not done that because there has been a 60% chance of rain for the past 2 days and tommorow as well although we have not gotten a drop. I have proped up the carpet alllowing water to drain from it. I have the hardtop and doors back on so it can't collect any more water.
My complaint is not that it got wet but it filled with water while the rest of the back just got damp. I think the top of the carpet is a little water resistant and as it shed water it ran into the storage area where it soaked into the backing. The top of the carpet is dry as is the backing except where the storage area is. They put a plug in (which will be removed from now on unless I plan to ford a creek or someting) but the water still had to be mopped out as it does not all run to it. Also with the lid unless you take it off and lift the carpet to get airflow and allow the backing to drain it will never dry. I like the storage area but being a jeep it should have been designed to be waterproof or never lined with carpet in the first place. Also the design of the storage area does not promote draining out the plug hole unless you force it out.
Untill now I thought most of the jeep was well designed except for a few bugs. I now begin to seriously wonder how many more not well thought out designs there are. I know pull the carpet and rhino line however I can't afford that now so I guess I will be watching the weather a lot more closely when the top is off and run for cover the first sign of rain.
I wish somebody would come up with a decent
tonneau cover.
tonneau cover.
I just put on the bestop duster and windjammer yesterday and drove around in the rain today in OKC. Didnt get wet at all in the back and I dont even have the back of the duster latched down (they forgot to put the F&^% rail in the box)
Cover is tight and pretty easy to install
It took over a week for mine to dry out.you have to keep the top of the storage area open some for it to dry.i had 6 1/2 gallons of water that i vac out of my jeep using a wet/dry vac
I agree...I think you're thinking about this all wrong. It's a good thing that it collected. Otherwise you would have had water all over the place. This was probably by design, and in fact the way they wanted it to work. Seems logical to me.
I was thinking about pulling the carpet out of the rear of mine as well... Thought about putting some of that textured liner stuff on it... do you have any pictures of what yours looks like w/out the carpet back there?
Logical yes however it all drains into a STORAGE COMPARTMENT not a bilge. Of course I did not think about this eventuality as I have been leaving the jeep when the top is off under cover at home on days it called for rain. My main hope is this helps to keep someone from making an expensive mistake. I saw where one guy had his registration and papers in it which is bad but God forbid someone puts an expensive camera or cell phone in it (afterall it is a locked storage compartment) while at the beach does not get caught in a storm.
