Warning stickers
When i peeled mine off it left alot of the sticker and residue.. I just kept sticking the sticker i peeled off on the residue and eventually it pulled all off it off
Also try WD-40 or Goo-gone i bet both those will help
OP, heres how you do it:
Get the hair blow dryer out of your wife/girlfriends hand. Go out to the little yellow bastard that makes you feel ill everytime you sit in your awesome JK. Heat those F'ers up. Youll know youre hot enough when you cant keep your fingures there for more that a second or two. Focus your heat at one corner until the sticker comes up with ease. Now the trick is SLOW, just cause you have the sticker in your grips doesnt mean it'll rip right off. Oh it will, but glue will be everywhere. Continue to heat while pulling over, again, Very slow and all the glue will come off with it. Pay attention as you pull. If a bit of glue snaps back onto the visor, push the sticker back on it and heat some more. A bit of cleaning with some rubbing alcohol and your good.
