Warning lights
I had a brake job done a month ago they probably cracked it. I will look in to it going to pull off my wheel and look at it
There are lights that will come on when you have a bad speed sensor, or damaged wiring. Can't tell from your picture if those are the lights you have on--it's pretty small and foggy. Anyway, the pop may have been the wiring getting hung up in the steering/suspension parts. Check it, too.
well it is fixed it was about a 20min job just had to replace the left rear wheel speed sensor the part was $22.80 I had a hard clump of mud in there that came loose when I hit a bump and broke my sensor. after I replaced the sensor I drove it about 100 feet and the lights on my dash went out thank you guys for your help. Bruce
