Valve tap and rough start.
Old 12-11-2010 | 08:53 PM
  #21
shindiggsxr's Avatar
Its the oil filter! I started out using mopar filters and was getting dry starts switched to fram extra guard and no more dry starts no matter how cold it gets. I was also told by a service tec to stay away from the filters that you get free with oil that is on sale from auto parts stores.
Old 12-12-2010 | 03:31 AM
  #22
bostonMA's Avatar
The filter can be a problem, but it does not explain why so many have problemsd only in the cold without changing the filter.
Anyway, the cold should decrease the amount of drainback as the oil is thicker.
Old 12-14-2010 | 04:19 AM
  #23
johnyrrr's Avatar
Fram does it on mine as well as the ford motorcraft i just changed from a suggestion on here to make the ticking go away.....it didnt change anything.
Originally Posted by Strick
I have had the Jeep 2 winters now...I am using a Fram oil filter because of the Mobil 1 filter issues. It DOES NOT do this in warmer weather. It used to (with Mobil 1 filter) before I went to a different filter. Since I started using Fram the issue went away in the Spring-Summer-Fall. Have used Mopar filter...same issue. Now we are talking ZERO degrees F outside at night plus some pretty nasty wind chills. Maybe this is the reason, but it is not a filter issue. Plenty of us solved the filter issue a long time ago.
Quick Reply: Valve tap and rough start.
