Valve tap and rough start.
I am using Mobile 5w/20 synthetic and was getting dry starts with both K&N and Mobile 1 filter.. Really frustrating!
Finally after reading some posts here, I switched over to a WIX and no more dry starts. So far the WIX filter cured the problem for me. Even when in the single digits no more dry starts.
I too have this problem. Only a second or two upon start-up. I have the lifetime powertrain, BUT that doesn't mean I want to use it. I also have a wish-list a mile long that doesn't include a $250+ add-on. I guess I will continue ignoring it unless this post leads to a cheaper solution.
Oh but I don't need it I have lifetime powertrain , I'll just get the engine replaced! LOL
1 The design of this type of oil pump ( inner and outer rotor ) tolerance has to be kept to a minimum to be efficient then they mount it on the receiving end of the crank where it has, torsional, vibrational harmonics, and then mount it in a aluminum housing with all its expansion.
2 Engine assembly plant, and how they prep blocks for assembly and what they use. Are they using a substance that can block the bypass or partially block the bypass, who know's
All I can say is that the carbon cleaner worked for me with little to no oil consumption
33
TRy a NApa Gold filter and maybe adding a quart of synthetic with 5 quarts of regular that did it for me. Slight light tap but not musch at all. Probably will not harm anything for 200,000 miles.
