Valve cover and PCV removal
OK so a rant....
Is there anyone else that would like to meet the engineer who put that PCV in the location it is in and give 'em a sock in the nose? I mean the wiring harness and other lines make the top Torx screw impossible to get at. I am working on mine right now and the bottom wasn't too bad but still a pain, but the top... It is in there tight.
The Torx is a pain, don't use a hex head that wrench or standard socket may be able to grab onto.
Oh well I will get it at some point.
Rant off....
Rant off....
yup, it sux. are you using a small bit driver and torx bit? that is what I've always used.
