Unit bearing
Old 08-03-2015, 10:27 AM
Baddkarmaracing's Avatar
when I did my axle bearings I couldn't press them off so they were cut off with a cut off wheel on a die grinder and then the shaft cleaned well and the new stuff all pressed on, I have had to 3 axle bearings all on the right rear of my jeep for some reason (first 2 were on the same shaft 3rd was a different housing and all) and that's how its been done everytime and has worked well (maybe not the 1st time lol )
Old 08-03-2015, 09:34 PM
Jnorman831's Avatar
At our shop we charge $30.00 to do the bearing swap. And you should change the seal sense your there anyways. Just take it to your local machine shop. It only takes 15 minutes to do the job.
Quick Reply: Unit bearing
