Um...yeah...about that...
Old 12-09-2007 | 07:42 PM
JMac's Avatar
Default Um...yeah...about that...
Sooooo...doing a little trail cruising with my JK today, and was having a blast! Some nice rocky trails, climbs, mud, river fording, etc.. Nothing TOO horrible, I thought - no dents, no pieces of the Jeep left on the trail. Towards the end, though, after some kind of intense articulation over rocks (for a stocker, anyway), my suspension developed a "click". It's kind of a click/creak noise when I go over bumps with the wheels turned a bit. It won't do it when the wheels are straight-on unless it's a LARGE bump, but with wheels turned, I can reproduce it almost at will. It doesn't do it when driving normally.
I've looked under the body and I don't see anything obviously broken or dangling, and the handling and suspension seems to function very well. I just dont know what that CLICK noise is. It does seem to be related to lateral body movement over the suspension. Does anyone have any idea what might be happening here? I'd sure appreciate any ideas you all might have!
Old 12-09-2007 | 07:55 PM
Rugbyduck's Avatar
Default Doubt this is it...
But... I developed a click of sorts when turning after i had some extreme articulation too. Seems it was the brake line rubbing against the tire. Extreme articulation took the line out of it's normal "kink". You know, how when you go to roll up a hose and it wants naturally to go one way when you want it to go the other... same thing happened here. I had to twist it back to the natural "kink" and zip tie it.
Old 12-09-2007 | 08:21 PM
JMac's Avatar
Thanks for some quick responses - but:
1. No sticks or wheel obstacles, just checked thouroughly.
2. I don't see any rubbing with the brake lines - they are nicely out of the way and still firmly attached to the OEM brackets.
It's a rather loud, sharp, metallic CLICK - sounds almost like it's coming from the front sway or somthing. It's definately coming from the front - wife said it sounds every time like it's coming from underneath, about a foot back from the front bumper. I just don't actually SEE anything wrong there.
You know, maybe a "creak" is a better description - short, loud and sharp. Definately metallic.
Old 12-09-2007 | 08:25 PM
07JKX's Avatar
make sure the bolts are tight on your sway bar links... alternatively, i will crawl up under my jeep every once in a while and just lay there looking at every square inch... poking... prodding...
Old 12-10-2007 | 04:56 AM
dmerc's Avatar
Check the sway bar bracket welds very closely.
Old 12-10-2007 | 05:53 AM
Rubidonn's Avatar
I'd agree w/the above bolt tightening... and defenitely check your track bar. That seems to be one of the more common areas that need periodic checking. So check the following and tighten:
Sway Bar links (I honestly doubt this is it though)
Track Bar (good chance this is it)
Control Arms (probably isn't this either)
Old 12-10-2007 | 07:01 AM
bly109's Avatar
Definitely check the trackbar. On both my cherokees the track bar bolt at the axle would loosen a little bit after wheeling and I would get a clunk when I would turn the wheel and hit a bounce. I havent had this on the JK yet, but Im almost obsessive with checking it.
Old 12-10-2007 | 07:16 AM
Rubidonn's Avatar
Originally Posted by N2rock
Mine does it too- also happened after a day of off-roading, also developed after some nice articulation. So I found a spot where I could create the sound at will, then had one of my wheeling buddies stand there and check it out. It was the spring stretching out.
Check this out
http://youtube.com/watch?v=eeT7DEa87vw
it is a video of my JK. Turn up your speakers and listen at 35-seconds (as I'm getting some articulation on the front end) and you'll hear it. Is that similar to the sound you're hearing on yours?
That defenitely sounds like a track bar needing tightened...
Old 12-10-2007 | 01:58 PM
JMac's Avatar
Thanks for all the replies, folks
Well, I went under and tightened everything - well, tried to. Everything felt pretty good, actually, and I really saw nothing wrong. But it's not making the noise anymore, either, so all's well that ends well. I don't really feel like I did much of anything, but good enough!
Thanks again, guys - always appreciate help in a pinch
Old 12-10-2007 | 02:00 PM
Rubidonn's Avatar
Wouldn't hurt to actually get a torque wrench out for the track bar... 125 ft-lbs is quite a bit... at least I thought it was...
Quick Reply: Um...yeah...about that...
