Two "Zippers" on sunrider??
Took the top down today. Does the sunrider have two zippers, the little black pieces I mean? On the rear window they were. It just didn't seem to want to work right. Please advise??
both the side windows and the rear window needs to be unzipped and removed before putting the top all the way down. Is this what you mean? If you are just opening the sunrider part then you do not need to unzip /remove the windows.....
Location: Hangin in the sunshine state....staging forum..
not sure what you mean, but check out the video on jeep.com
http://www.jeep.com/en/owners/soft_top_guide/
If you're talking about what I'm thinking...
When you install the rear window, you zip up from the left side and all the way around to the lower right side.
Then - you have a zipper on the lower left, and another on the lower right. This allows you to open both sides of the rear window (and roll it up) without having to remove it.
To remove it completely, start on the right and zip all the way around to the lower left.
