trying to muddle my way through the build sheet
I requested a build sheet from Jeep and they promptly sent the info back. What I find interesting is that the transmission cooler is not listed. I could have sworn that I had one. I will have to trace the lines from the cooler in front of the main radiator and see where they go..... They do list an engine oil cooler - did they actually run a line that cools engine oil through a radiator of sorts?
Also it looks like I don't have seat air bags I'm kinda happy about that - easy seat upgrades!!
Model Year 2012
Body Model JK J M 74
Color PRP- Deep Cherry Red Crystal Pearl Coat
Sales Code Description
A7 Cloth Seats w/Adj. Head Restraints
X9 Black
APAS Monotone Paint
BABS 160 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BNGS Hill Start Assist
BNHP Hill Descent Control
BNMP Traction Control
BNSP Electronic Roll Mitigation
BPTP Hydraulic Assist Brake Booster
BRWS 4-Wheel Disc Brakes
CACS Low Back Bucket Seats
CDBS Reclining Front Seats
CDHP Driver Height Adjuster Seat
CFNS Rear 60/40 Folding Seat
CGXS RR Head Restraints Outboard Seating
CG3S Advanced Multistage Front Air Bags
CKES Front Seat Area Carpet
CKFP Rear Seat/Wheelhouse/Cargo Carpet
CKLS Cargo Compartment Floor Mat
CKTS Cargo Tie Down Loops
CLES Front & Rear Floor Mats
CLMS Sport Bar w/Full Padding
CSMP Front Seat Back Map Pockets
CS2P Freedom Panel Storage Bag
CUFS Full Length Floor Console
CURS Rear Compartment Covered Storage
CUYS Storage Tray
CV1P Vinyl Shift Knob
DBAC All Automatic Transmissions
DGJ 5-Speed Auto W5A580 Transmission
DHES Command-Trac Shift-on-the-Fly 4WD
DJRS Next Gen. Dana 30 Solid Front Axle
DMCS 3.21 Rear Axle Ratio
DRZS Next Gen. Dana 44 HD Rear Axle
DS7S Conventional Differential Frt Axle
DS8S Conventional Differential Rear Axle
ERB 3.6L V6 24V VVT Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GCFS Full Metal Doors w/Roll-up Windows
GEDP Tinted RR Qtr & Liftgate Windows
GFAP Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNUS Sliding Sun Visors w/Mirrors
GTPS Manual Mirrors, Fold-Away
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
JA2S Premium Instrument Cluster w/Tach
JCDS 100 MPH Primary Speedometer
JE8S Manual Door Locks
JFJS Temperature & Compass Gauge
JF8S Manual Windows
JHAS Var Intermittent Windshield Wipers
JHBP Rear Window Wiper/Washer
JJFS Single Low Note Horn
JJJS 12V Auxiliary Power Outlet
JKAS Glove Box
LABS Tire Pressure Monitoring Warning LP
LAXS Front Passenger Seat Belt Alert
LCLS Front Dome w/On/Off Switch Lamp
LHES Rear Dome w/On/Off Switch Lamp
LMAS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
MBAS Black Front Bumper
MB5S Black Rear Bumper
MFRS Black Front Frame Overlay
MFTS Body Color Grille
MGXS Wrangler Unlimited Badge
MT2S Trail Rated Badge
MUGS Accent Color Fender Flares
MVCS Jeep Badge
MVJS Sport Badge
MX3 Black 3-Piece Hard Top
MX9P Delete Sunrider Soft Top
NAS 50 State Emissions
NF5S 22.5 Gallon Fuel Tank
NHAP Engine Oil Cooler
NHMS Speed Control
PRP Deep Cherry Red Crystal Pearl Coat
QRPS Deep Cherry Red Crystal Pearl Coat
RCGS 8 Speakers
RDDS Fixed Long Mast Antenna
RDZS Steering Wheel Mounted Audio Ctrls
RESS Radio 130
RSUP Audio Jack Input for Mobile Devices
SBAS Power Steering
SCAS Steering Wheel
SDAS Normal Duty Suspension
SHAS Front Stabilizer Bar
SHCS Rear Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TRMS P225/75R16 BSW On/Off Road Tires
TZAP Goodyear Brand Tires
WKBP Matching Spare Wheel
WLCS 16X7.0 Lux Styled Steel Wheels
WLYC All Steel Wheels
XBNP Tip Start
XEES Fuel Tank Skid Plate Shield
XEFS Transfer Case Skid Plate Shield
XEWS 2 Front & 1 Rear Tow Hooks
XJFS Tethered Fuel Filler Cap
XJGS Non Locking Fuel Filler Cap
XLNS English/USA Language
XPFS Protective Coating and Remover
XSBS Base Interior Accents
X8ZS Seat Parts Module
X81S Instrument Panel Parts Module
X83S Front End Parts Module
X86S Complete Chassis Parts Module
X88S Tire & Wheel Parts Module
X92S Complete Body in White Parts Module
X94S Complete Painted Body Module
YAAS Build To U.S. Mkt. Specifications
Model Year 2012
X9 Black
APAS Monotone Paint
CUYS Storage Tray
JF8S Manual Windows
JKAS Glove Box
LNJS Fog Lamps
LPSS CHMSL Lamp
MVCS Jeep Badge
MVJS Sport Badge
NHMS Speed Control
RCGS 8 Speakers
RESS Radio 130
SBAS Power Steering
SCAS Steering Wheel
XBNP Tip Start
NHBP stands for Auxiliary Transmission Oil Cooler, probably applicable to those vehicles that have the normal transmission cooler in the engine's radiator, and those vehicles with a small transmission cooler at the bottom of the A/C condenser, like the earlier JKs.
Since your later JK has only a large external transmission cooler, (making an aux cooler virtually unnecessary), there is no need to code it.
I noticed your build sheet does not list an engine water cooler. Apparently not every item on the JK is listed on the build sheet.
