Trying to Bleed Slave cylinder
I recently had a shop install a new Centerforce clutch to replace my OEM one that went out at 20k miles. It’s been amazing up until it seemed to lose pressure, making it difficult to shift into first and reverse and sometimes into 2/3/4. After I pump it a couple of times it seems fine.
I am trying to bleed the slave cylinder now to see if they just left some air in the system, but it doesn't seem to be working. There isn’t the normal nut to open and close the nipple it has this hand tunable top on it. However, no matter which way I turn the thing, it won’t bleed out. Picture below, any help would be appreciated.
- Luke
- Luke
sweet, just a question, how did it turn out and i know this may sound stupid to ask but how EXACTLY did you bleed your slave( step by step after installing it on the trans) ,im in the same process of doing it to mine,and just want to do it right this time.we broke the other one i ordered,so im waiting for a new one. and did you ever encounter this "o-ring" everyone talks about. did it look like this
Attachment 441684Attachment 441685Attachment 441686Attachment 441687
1) Attach bleeder hose to nipple
2) Have someone sit inside and pump the clutch 5-6 times then hold it down
3) Open the valve (had to use a crescent wrench & it goes a little over a quarter of a turn)
4) Close the valve when you release all of the pressure
5) Let the pedal back up
6) Rinse and repeat until you don’t see any more bubbles or about three times
--- I didn't see that o-ring but its probably for the line coming down from the master
Problems with leaky slave - did not lose my oring, anyone else?
Attachment 440423
- Luke
Attachment 440423
- Luke
I guess I would LOVE to hear from anyone who followed the prescribed procedure, re-using the old o-ring, and had a problem similar to mine. It didn't look damaged, but then again I didn't put it under magnification. No splits or cracks. The fit was probably on the loose side going in compared to how hard it was coming out.
Has anyone every experienced a leak AFTER PROPERLY SEATING A RE-USED ORING?
Thanks!
Don't even mess with that. Just reverse bleed it and be done with it. manually push the slave cylinder in from under the jeep, all of the air will work its way up and you're good to go. Takes minutes.
Exactly. I do just that, never had an issue. Until now. Leaking like a stuck pig WITH the bushing installed. Cross fingers all I need is a fresh bushing. This one has been through two slabes and 76k miles
