Transmission or transfer case leak?
So I was about to do a transfer case fluid change. Removed the skid plate and noticed it was somewhat damp with fluid and there was a drop of fluid hanging from above. I never noticed anything leaking on my garage floor so it must be a slow leak. Any idea if this is from the transfer case, or transmission? Should I not bother replacing the transfer case fluid until I figure out and fix the cause of this other leak?
Pic is on the front side of the transfer case...but on the back side where the drain and fill plugs are it is totally clean.
Yoni (12-19-2021)
It looks like a bad front drive shaft to me. You are "Slingin' Grease." Take a look above the transfer case on the aluminum heat shield and see if the grease is above up there. You can then rule out the transfer case as the cause if its above. Otherwise follow the directions above and clean it all up to get a better look. I'd also check the fluid level of the transfer case or even perform a TC service which is super easy and under $20. You can see how much fluid come out of the TC. The TC uses ATF+4 which is red in color. So unless its never been changed on your vehicle before, I would say thats the dark black drive shaft grease.
Yoni (12-28-2021)
