View Poll Results: Does your Transmission Shudder in Reverse when on a hill?
Yes
38.46%
No
53.85%
Yes, but Jeep Fixed it.
1.54%
Yes and Jeep wont fix it.
6.15%
Voters: 65. You may not vote on this poll
Transmission Shudder...
Old 01-29-2010, 09:45 AM
warlord's Avatar
does it do it if you give it some gas in rev?
so far sounds like the cluch isnt fully engaged
Old 01-29-2010, 10:56 AM
Go for a ride with your dealer and show them what its doing, if your not there then it didnt happen is usually their point of view!!
Old 01-29-2010, 11:48 AM
I guess I should have stated its an automatic...
Old 01-30-2010, 06:16 AM
BigRedRubi's Avatar
Mine is doing this exact same thing. Just came back from the dealer yesterday. They said no problem found. I will bring it back and take the tech for a ride myself....
Old 01-30-2010, 09:17 AM
scbesse's Avatar
No Issue here. 08 auto 40,000 km. Maybe its the esp/traction control being stupid
Old 01-30-2010, 09:43 AM
CJK
CJK's Avatar
Originally Posted by seairland
Mine did it before I re-geared.
I had 35's and when backing up on a small hill, it felt like the tranny or the tc was shuddering.
After re-gear, its not there anymore.
Hmmm........
Common problem likely caused by driveline bind in reverse. Some JK's do it worse than others. Usually occurs at slow speeds on inclines - what you're feeling is the driveshaft joints "sticking". Magnified by lifts (increases the angle) and larger tires (increases the amount of torque needed to move). As you gain speed and the shaft joints start moving freely the shudder decreases - probably why your regear cured it since your driveshaft now spins at a faster rate.
Old 01-30-2010, 11:58 AM
ArizonaHeat's Avatar
My '08 doesn't need a hill or trailer to shudder in reverse; does it on my flat garage floor while backing-in. Slight turn of wheel either direction makes it worse. "Could not duplicate...." garbage response from dealer. And I'm full stock. No mods.
Old 01-30-2010, 09:45 PM
warlord's Avatar
i knew it was an auto but they have clutches too, you just cant control them with a pedal
Old 02-02-2010, 09:17 AM
Default People who didnt have a problem...
Of the peoplr who have not had a problem with their tranny I have noticed that out of the 27 votes for no that 9 of you were driving a manual... This thread pertains to the Automatic...
Old 02-10-2010, 09:59 AM
Default Official Jeep Answer...
LOL!! ok so get this... Jeep is "officialy" calling this "WHEEL HOP"!!!
That is just to Funny!! When I asked them why the manual does not do it he just said "I dont know?"
If your Jeep has a "wheel hop" problem... Make them fix it! I am not done with them yet...
Quick Reply: Transmission Shudder...
