Transmission pan gasket
Here is how I made their installation much easier:
These allen head bolts, and the rounded-end allen wrench make it so you don't have to have a straight shot at the bolts when installing them.
This mod will make the next transmission service a lot less messy:
Did you just drill an tap a drain bolt in there or did you make a cut out with the dip in the pan an weld that in?
I made a little steel tab for safety wire and welded it next to the drain plug.
I did not use RTV. I used a petroleum-based grease To seal the gasket. I did this because a transmission rebuilding expert advised me to do that rather than RTV. So far I have no leaks but it's only been a few weeks.
A thin bead has worked fine on mine.
