Transmission fluid leak?
Just got under my jeep and noticed it looked like transmission fluid was being flung around on top of the skid plate but couldn't find where it's dripping from... An suggestions on where I should check?
Does it look like it may be leaking at the front of the transmission (between the bell housing and oil pan)? My transmission started leaking there the day after thanksgiving, turns out the torque converter hub broke, causing a massive leak. I posted up about it in another thread on here, see post #29 and the read onto page 4. Good luck hope it's not too costly
https://www.jk-forum.com/forums/stoc...-311383/page3/
No it's after and just a small leak but found a local dealer that will do the work even with the lift and 37"s or at least that's what they are telling me now
