transfer case stuck in neutral
#41
Originally Posted by ricksjeep10
I just had to fix both ends on mine. On the shifter side, I used a washer between the cable end and then put on the e-clip. Couldn't fit a washer on the transfer case end so I just used the e-clip.
#42
Havn't had it off-road since I fixed it but it feels the same as before (shifting from 2hi to 4hi to neutral to 2lo and back). All testing was done in the garage.
#43
#45
Originally Posted by Aurelius
Put a couple tie-wraps on there and call it a day.
#46
Mine broke twice on my 07, once on each end.
I used a drill to lose the bushings and sawed off skateboard truck bolts to link it together. Worked like a charm, except my computer wouldn't recognize the shift points. I had that little yellow 4WD indicator on for a bit.
The new cable and shifter fixed all that though, no light in the dash, and a bulletproof shifter.
Hooking it up on the console side was a bitch though, just getting the console out is ridiculous.
#47
cheap part disabling a vehicle?
If you think about it ( and you probably shouldn't) just think how much we depend on a 79 cent Schraeder valve in the valve stem, now that's trusting.
#48
I know this topic is probably overkilled but this happened to me on a trail today and would like to know if there are pictures or a video of how to replace this part ..... thank you!!!
#49
I drilled out the black linkage eye to 1/2" with a step bit. Used a 1/2" screw cap and cut the tip off (used as a new bushing). Then used a cotter pin to hold everything together. There is a groove on the nipple that accepted it perfectly.
