Tranny Rattle
Old 12-01-2007 | 12:24 PM
joetter's Avatar
Default Tranny Rattle
I just picked up my jeep yesterday!!!! However, I am already annoyed with a rattle that it has. It comes from the stick. If I even just rest my hand on the shift nob it will stop, but if I'm not touching it, the thing makes a ton of racket. Has anybody experienced/fixed this?
Old 12-02-2007 | 05:33 AM
rickl's Avatar
Default loose cap in shifter
I had been getting same rattle under torque,went away putting finger on cap(little piece with shift pattern)on shift knob,used a pin to apply a little super glue to cap,now no rattle
Old 12-02-2007 | 11:39 AM
ckarate2's Avatar
there are 2 bushings inside the shift housing holding the shifter into position.
they get a little warn and cause the rattle common problem/
pop the shifter out and replace the side bushings and walla rattle solved
good luck
Old 12-02-2007 | 12:48 PM
Tommy3rd's Avatar
got the same problem, but haven't had a chance to fix it.
Old 12-02-2007 | 03:13 PM
horwitzs's Avatar
Mine just started doing this about a week ago as well (~10k miles). Mostly it rattles only when I am really on the gas, like accelerating or climbing a hill, and if I just touch my finger to the cap on the top, it stops.
Glad to hear you fixed it so easily.
Old 12-02-2007 | 03:16 PM
Omega Man's Avatar
I used some double sided sticky tape and it has worked for over 13k miles.
Old 12-02-2007 | 07:49 PM
joetter's Avatar
I got excited when I read it might be the cap however, it's not. While i was out driving today, I put my finger over the cap, and nothing. Then i tried just holding the stick a little closer to the shift boot. That stopped it, so it can't be the cap. It seems to happen mostly on acceleration, the whole stick starts to shake back and forth pretty bad. It's a light shake, but it moves the stick pretty far in every direction.
Old 12-03-2007 | 12:38 AM
Tommy3rd's Avatar
the rattle comes and goes. sometimes it's fine, then for some reason, one wrong shift then it starts up again. playing with the cap on the shift knob or banging on the knob sometimes works, then it comes back again a few days later.
Old 12-03-2007 | 12:41 AM
Tommy3rd's Avatar
can they get worn out that fast? he's had his jeep 1 day and i've had mine 1 month.
Old 12-03-2007 | 03:26 PM
Mossimo777's Avatar
Same problem... started at 1500 miles.
Whats the best way to get the cap off to put the double sided tape underneath? I'm tempted to just say something next time I'm at the dealer.
Quick Reply: Tranny Rattle
