Trailer Towing Question.
I towed a Mule 610 in a trailer the other day & the wag was horrible. I really don't know much about towing, since I've only towed a very light boat with a very big truck before.
How do I stop the wag? Do I need more weight on the tongue, a bigger drop hitch to level the trailer?
I have an unlimited with the tow package (3500# rating).
The Mule weighs around 1000# and the 5x10 trailer is kin of heavy with the wood floor, but I don't think I'm close to limits since acceleration seems normal.
Any tips from you guys that have done some real towing?
THis is always a problem with a vehicle that has rear coils. The leaf springs take a lot of sway out.
You may want to put more air in your rear tires.
You either have to much wight on ball or not enough.
When you load it, have someone else watch how the rear sits on your Jeep, you want it slightly down from when the trailer was empty then make the spot where its correct, might have to back it on. X3 with the others eather too much weight or not enought.
Don't know how important it is, but I'm using a 5 3/4" drop on the jeep, and a 8" drop on my dodge to get the boat trailer level.
Tounge weight is the key!
Trailer sway is almost always caused by too little tounge weight. Some landscape trailers are bad about having their axle welded too close to the front of the trailer. Ask me how I know, that is another story. Trailers should be as level as possible, expecially if it's a tamdem axle.
This is what has me curious. Just how much angle (not sure angle is the right word here?) is there? How far do you need to drop the ball so that the trailer is sitting level? I would think that too much of an angle would make for some squirrelly handling.
Don't know how important it is, but I'm using a 4" drop on the jeep, and a 8" drop on my dodge to get the boat trailer level.
I push the towing limit with my 2 door with my camper and I don't have a sway problem. But I also have a leveling hitch with sway control on it per the Jeep manual recommendations.
