Towing Mileage Help
I dont have 3.21's I just have the stock unlimited or is this the stock ratio? So I assume towing with my 35's are out of the question? I have the stocks wheels and tire but I would also have to carry these 35's in that trailer and its not very big to start with. It would be easier to put the stock wheels in the trailer not because of gas mileage but for storage room.
Location: Simi Valley, Ca., Taylorsville, Ut. and places in between
1 Post
Dont know what year your jeep is but I know on my 09, its got the tralier tow package and has 3.73 gearing with auto.
IMHO, anything less than that might be asking for trouble.
Where can I get the tranny cooler someone else also suggested this.
Here is a write-up on a popular B&M cooler.
https://www.jk-forum.com/forums/show...ghlight=cooler
I have stock Unlimited gears
Rubicon? You have 4.10's.
Non-Rubicon with tow package? You probably have 3.73's.
Do you get those Aamco commercials out your way? The ones that tell you that the vast majority of transmission failures are caused by heat? Your JK with stock gears, big tires, a heavy load and no transmission cooler is the poster child for that commercial...
So,
OD off. Stock tires. Tranny Cooler.
Or at least,
Take some extra breaks from for a few or while you let it all cool back down so your transmission doesn't .
First thing, you need to know what gear ratio you have.
Assuming you have a 4 door:
3.21 and your limit is 1000 lbs.
3.73 or 4.10 and your limit is 3500 lbs.
Both limits are with stock tires.
There are a few ways you can get your ratio.
Window sticker
Build sheet from dealer
Build sheet from Jeep.com
If you bought your Jeep used, you don't know what you have.
If you want to know for sure, and remove all doubt, do this:
Chock the front tires, fore and aft.
Put the transmission in neutral.
Emergency brake off.
Jack the left rear tire off the ground.
Put a jack stand under the frame, just in case the jack fails (had to add this).
Put an index mark on the aft end of the drive shaft, visible from the left rear wheel.
Put an index mark on the left rear tire at the 6 o'clock position.
Rotate the left rear tire 2 complete revolutions while counting how many times the index mark on the drive shaft passes its original position.
That number will be your axle ratio.
Remove jackstand and lower jack.
Put transmission in gear or Park, and/or apply emergency brake.
Remove chocks.
If you have limited slip, jack up both rear wheels and rotate one revolution, making sure both tires rotate equally.
If the driveshaft rotated almost 3 1/4 turns, you have 3.21
If the driveshaft rotated almost 3 3/4 turns, you have 3.73
If the driveshaft rotated a little over 4 turns, you have 4.10
Window sticker
Remove chocks.
1 Post
IF you want a build sheet for your Jeep, go here.
Email return fairly quickly. Should answer your questions.
http://www-5.chrysler.com/wccsapp/un...ull&category=U
Thanks for all your help guys! I'm trying to figure out what gears I have now. I just want to keep my tranny healthy and I know this move is most likely going to be tough on my vehicle.
Do I need an towing extention thing since I just put on the RC 3.25" Lift?
Here is a recent thread on drop hitches:
https://www.jk-forum.com/forums/jk-talk-26/what-size-hitch-drop-105254/
Check SaginawMikes post for some measurement info. Or just run over to your local uhaul and back up to a trailer.
Sorry it's an 08. I sent a message to get the build or whatever and they still havent got back to me yet. Hopefully by the morning
