Towing a JKU Rubicon behind an RV, any advice on equipment?
#31
Here's a link to Towing Worlds State requirements. Hope it helps.
hxxp://www.towingworld.com/articles/TowingLaws.htm
John
John
#32
Apparently the 2011 manual needs an update. There is no steering lock in our '11 automatic. Spent some time on the phone with factory tech support. According to them, there is no need to leave the key in or disconnect the battery. They also said it would be fine to run a +12V line from the coach to the Jeep battery to keep it charged for tail lights and/or a braking system.
#33
Location: Simi Valley, Ca., Taylorsville, Ut. and places in between
1 Post
FWIW, the way ours is wired is I have a charge line for the Jeep in the 6 pin plug.
As for a rubber smell from the Jeep, I sometimes get it after towing for a while.
It disappears after about five minutes of driving the Jeep.
Hope this helps
Hope this helps
#35
Auto or Stick
I haven't heard anyone talk about their Jeeps being auto or stick. Does this have anything to do with towing with 4 down or 2 down (rear) when using a dolly if your JK is a auto. Making a move soon and might need to tow the JK behind a U-Haul. They say the drive shaft needs disconnected when using a dolly. The manual states "Front or rear wheel lifts should not be used, internal damage will occur." By lift I guess they mean a dolly?
#36
I haven't heard anyone talk about their Jeeps being auto or stick. Does this have anything to do with towing with 4 down or 2 down (rear) when using a dolly if your JK is a auto. Making a move soon and might need to tow the JK behind a U-Haul. They say the drive shaft needs disconnected when using a dolly. Our manual states, just don't do it.
#37
I'm researching how to best set up my Rubicon to be towed by my RV. Though I know towing 4 down is OK with the JK, I'm still considering a dolly for the flexibility it would allow. I'm looking for any experiences good / bad with setting up towing 4 down or by a dolly. I'm really leaning toward 4 down, but am overwhelmed with the available variations of tow bars, tow bar mounts, brake buddies, etc. Yet leaving the possibility of towing my other fwd vehicle makes the dolly option attractive too. My Rubicon is completely stock at this point, so no special considerations there. Any experiences to share?
#38
Great thread. Thanks to all sharing.
We will soon be ready to get our towing set up put together. 2011 Rubi Unlimited with a 41' Gulf Stream Atrium (DP). The Currie plate/Blue Ox set up sounds good.
Should we be especially careful in selecting a place to install the plate?
We're in the Vancouver, WA/Portland, OR area.
Thanks again.
Thanks again.
#39
Thanks again.
Thanks again.
http://www.currieenterprises.com/cestore/contact.aspx
l
