Towing with diesel JKU
Well, guys, here one of the first Google searches for "Jeep JK haul" in Germany: h ttp://www.vierkantoffroad.de/product_info.php/anhaengerkupplung-anhaengelastauflastung-2000-3500kg-fuer-alle-jeep-wrangler-jk-07-p-1863
Remove the space between the h and t
My hitch is rated for 3330kg, because it can be removed. I can upload a picture of my official papers for the jeep.
The trailer is needed to have brakes, of course. Don't know if that's needed in the states.
My 2.8 CRD from 2008 is rated at 3500kgs in Germany. Trailers around 1.5tons won't even budge, only when breaking and going through corners you know that you have a trailer behind you.
Transmission is a 545rfe, known for its strength towing (Rams, Hemis)
the newer JKs with the merchant box are rated at only 1000kgs due emissions here in Europe, but it's possible to get then higher rated. But I haven't driven a newer one with a trailer.
Well, guys, here one of the first Google searches for "Jeep JK haul" in Germany: h ttp://www.vierkantoffroad.de/product_info.php/anhaengerkupplung-anhaengelastauflastung-2000-3500kg-fuer-alle-jeep-wrangler-jk-07-p-1863 Remove the space between the h and t My hitch is rated for 3330kg, because it can be removed. I can upload a picture of my official papers for the jeep. The trailer is needed to have brakes, of course. Don't know if that's needed in the states.
Fuel consumption is a question of wind resistance
Towed a 3meters high trailer, was 2,5meters wide. Really like a parachute for a drag-racer. Was like 18l/100km ~ 13mpg
Fuel consumption with 2,5" Lift, 285 tires 4.10 gears and winch, aev snorkel, bumper and carrier around 11l/100km ~ 21mpg on the highway, in the city: 12,3l/100km ~ 19mpg
The new 2014 JK 4dr and 2dr have a towing capacity of 1000kgs, because of the emissions test, called EURO5.
I can take a picture of the 2008 brochure when I get home tomorrow, hopefully it's not in the trash..
Nice comparison of towing capacities with large pictures
h ttp://m.auto-motor-und-sport.de/news/uebersicht-anhaengelasten-so-viel-duerfen-die-einzelnen-modelle-ziehen-1903305.html
My new 2014 Sahara unlimited 2.8l Diesel with 3.73 ratio is rated for 2000kg (4.409lbs) and 200kg (440lbs) maximum drawbar weight. All two doors model are limited to 1000kg (2.205 lbs). All this is according with the received leaflet updating the data from the owner manual.
1 Post
My 07 2 door 2.8 CRD is rated to 2000KG. The 4 door is rated to 3500KG. I've towed well over the rating on a couple of occasions and barely noticed I had a trailer on at all. Mine has the Tunit box, though, that brings the torque to 332lbs.
Cheers,
Daniel
