tow hooks
Check the for sale area, I have seen several sets of stock hooks go through there in the last month.
mine didnt come with them either. bought the rear one from a guy on here and got the front 2 from a friend. easy to install the rear, the front is a little more difficult becuase you have to cut the hold in the bumper but its easy enough to do just time consuming
Usually some in the For Sale section. Factory new run about $80.00.
They are not that easy to install. You will have to not only cut out the little square indentations for the hooks to come through. You will have to cut away underneith to get them to fit. The plastic is a bitch to cut.
Use a Sharp razor knife and extra blades and be patient.
Also look at how the hooks come out of the factory set up. You don't have to cut out the entire square indentations as the instructions show. Only about half.
The directions say to remove the grill. But some here say it is not nessessary. I removed mine.
If you don't have fronts I also bet you don't have a rear recovery hook. You will need that also if you ever want to go off road. The rear hook is a simple bolt on.
