Top speed in 4w high?
Old 01-24-2011, 09:15 AM
  #21
Furious Filipino's Avatar
In theory, as long as you are going perfectly straight, without undulations on the road, then 4 Hi as fast as you want.
If you have to do any turning and the tires cannot slip, even just a little, then you get drivetrain wind-up.
It's a part-time 4wd system designed primarily as a RWD platform, which is why the basic schematic goes:
Transmission -> Input Shaft -> Planetary Gear (for when you engage 4-Lo) -> Rear Drive Shaft
When you engage 4wd Hi, you are now engaging the front wheels via chain (because gear driven t-cases are loud) at the same rate as the rear wheels.
If you start turning, then the front and rear axles turn at a different rate and you get this if you it for an extended period at high traction:
http://rubicon-trail.com/4WD101/driveline-bind.html
Old 01-24-2011, 09:39 AM
  #22
Blendo's Avatar
Without a center differential, I assume the Jeep would act kinda funny in an avoidance maneuver while in 4wd. Maybe something to try in a big empty parking lot? Just don't flip it on the lid
Quick Reply: Top speed in 4w high?
