Tires on stock 16's
Old 11-12-2007, 09:32 AM
freeswimmingfish's Avatar
Default Tires on stock 16's
I have a 08 unlimited X. I will be doing the Terraflex BB 2.5" lift. I also will have 1.5" spacers.
What is the largest tire I will be able to put on my stock 16" wheels safely?
I do 90% on road driving with mild off road on weekends. What is a suggestion for brand and size?
Thanks
Joe
Old 11-12-2007, 10:51 AM
Embalmer's Avatar
265 75 16's is what 3 dif tire places told me. some have done 285 but think that would be pushing it
Old 11-12-2007, 11:43 AM
armycop's Avatar
P285/75R16 will fit on stock 16's. There is even some who are running a 295/75R16 on the stock rims. You may need spacers though, due to the width. Below is 285/75R16
Old 11-12-2007, 02:04 PM
ESPMike's Avatar
Armycop that looks great. Do you have any spacers running with that, and is it lifted at all? Id love to pull off 285/75R16 on the stock rims without lift, but I keep getting conflicting reports if you'll need spacers or not. Id rather avoid the spacers unless absolutely needed. If Im going to spend the $200 on them I figure I might as well put an extra $75 in and do the Skyjacker BB too.
Old 11-12-2007, 02:06 PM
Thanks for the replies,
I will prolly go for 265/75R16...
There does seam to be a lot of sidewall on yours, how does it handle with the 285/75R16?
Old 11-13-2007, 11:59 AM
ESPMike's Avatar
Im probably going with the 265 too, but damn the 33's look good. I just hear alot about rubbing off road, plus the extra cost of the spacers which sounds pretty mandatory to fit ok.
Old 11-13-2007, 02:44 PM
I got some 1.5" spacers today, so I should be safe.
Now for the lift.....
Speaking of spacers...should I install the spacers now, or just wait?
Old 11-13-2007, 06:32 PM
ESPMike's Avatar
Spacers for the 32"s? I was under the assumption the 265s would fit fine with no spacers?
Old 11-13-2007, 07:09 PM
1talljker's Avatar
Default Great thread, my question too
But it leads me to another question. Does that go for the stock rims on the X as well? I've got to get rid of these Wrangler STs.
Old 11-13-2007, 07:26 PM
ESPMike's Avatar
Im referring to the stock rims on the X. Seems like spacers might just be the way to go, in which case I'll be going with 285/75R16. Id much rather pull off the 33's.
Quick Reply: Tires on stock 16's
