Tire Pressure Warning Light
Old 12-07-2010 | 11:50 AM
  #41
Uafan's Avatar
Mine's been on constantly lately due to the weather. It's such a PITA..
Old 12-07-2010 | 11:52 AM
  #42
bill2k's Avatar
yea, i have to run mine at like 36-37
Old 12-07-2010 | 04:18 PM
  #43
drumnatural's Avatar
Mine has been coming on in the morning and then turning off in the afternoon.
Old 12-12-2010 | 07:22 AM
  #44
guyp3's Avatar
I swapped out 4 rims/tires (without installing the sensors) and drove around a couple days w/o a problem then the light turned on randomly... I think it's because of my spare, I didn't take it off, I'm gonna check it in a bit...
Old 12-12-2010 | 07:28 AM
  #45
I know for a fact that the 07-09 spare does not need a sensor. My spare doesn't have a sensor and I'm fine.
I don't know if jeep changed that for the 2010 and up.
Old 12-12-2010 | 07:29 AM
  #46
My rears were down to about 31 psi
Old 12-12-2010 | 08:13 AM
  #47
littlecricket's Avatar
I wonder what would happen if you parked next to a car with a low sensor and left the jeep running....
Old 01-30-2011 | 07:50 AM
  #48
randyd's Avatar
The sensors in our jeeps dont transmit till they are rotating. But if they keep coming on, increase the tire psi to 5-10 psi over what is listed on your door and drive around a bit, it should turn off..
Old 03-01-2011 | 11:35 AM
  #49
Rcs1125's Avatar
Originally Posted by 2008fx4
this.
went wheeling yesterdayon my 2011, and after airing down to 18 psi for the trip, i aired back up to 37 psi for the drive home. light never went out (25 mile drive). got home, filled each tire past 40 psi the light instantly went off. then i dropped the pressure back down to 37 and the light stayed off.
Had a similar experience. TPMS was indicating a fault (according to the manual) by doing the 10 second blink with a chime then solid light. I aired up to 41psi and the warning light went out after 25-35 miles. Has stayed off since (another 60 miles or so).
Old 03-01-2011 | 12:05 PM
  #50
largo's Avatar
I tend to disagree with the comment the spare does not monitor unless it is on the ground. The sensor is electronic, and sends out a signal all of the time. The spare can set off your TPMS. Check it.
Also, I would love to turn mine off as well, but in Utah we have a state inspection and they are looking at the valve stems and evidence your TPMS is workable, or they will reject the inspection. High price to pay for no TPMS>
Quick Reply: Tire Pressure Warning Light
