Tire pressure light not turning off
#31
At the end of the day, a TPM system for this vehicle is a bust. Chrysler should disable them all, and then we will not have this problem.
I had mentioned that the spare was monitored, maybe I was wrong .....got the info on this forum when I first got my jeep. Anyway.... 37lb worked for me. Seems overboard, but it is what it is.
#34
#35
drastic changes in air temp can effect the relative pressure in tires. if your tires are run close to the tpms warning threshold anyway, i think factory setting is something like 25 +/- a drop of a few pounds will trigger the tpms. i know a few guys that run nitrogen in their tires, they say the pressure is less likely to vary, but i can't speak from personal experience.
#36
It seems to be around 80% of the placard pressure.
#38
I used my Procal to set the threshold to 21 psi, and it will let you set it to 0 which essentially disables the TPMS.
