Tire pressure light not turning off
Originally Posted by mocar
I've fell victim to this as well, i didnt have my gauge with me one day after wheelin so I used someone elses gauge and filled to 35, light stayed on, aired up at a gas station with the gauge thats part of the nozzle, still had light. finally used a brand new gauge when I got home and two tires were under 35 still.
Ditto. My spare sensor has been sitting on a workbench for quite a few months now. Over a year??? The spare isn't monitored.
when i first bought mine the light came on and i ckecked with multiple gauges the pressure and never thought to check the spare.. took it to a local tire shop and they said your spair has almost no air. there was a piece of paper stuck in the bead seal on the spare tire and wouldnt let the tire completely seal. took the spare off and removed the paper then aired back up and never had a problem again.
I know on my GF's jeep, it was her spare that had a leaky valve stem. I replaced her TPMS in her spare and her light finially stopped going off. Seemed validate my thoughts.
Mine did this too. Twice. Both times after rechecking the dealer said two tires were under 35 and added some air then no problem. Have had no problem for a month now. Other gauges may have been old/faulty but two different dealers "fixed" the issue for now. One said sensor may be on the fritz but seems to be working good right now
Yes, exactly! I guess if you completely take the sensor away, removing the spare, it might just read the four.. I wonder how it affects it when you put different size tires on that require different air pressure from stock..
